Ana içeriğe geç
Nextbook NX008HD8G Back Panel Replacement
Neye ihtiyacın var
  1. Nextbook NX008HD8G Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. Nextbook NX008HD8G Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using your finger, open the plastic tab to the right of the rear-facing camera.
    • Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
  2. Nextbook NX008HD8G Back Panel Replacement: adım 2, 3 resimden 1. Nextbook NX008HD8G Back Panel Replacement: adım 2, 3 resimden 2. Nextbook NX008HD8G Back Panel Replacement: adım 2, 3 resimden 3.
    • Using your finger, remove the SD card by pressing down on top of it (toward the bottom of the device) until you hear a clicking sound.
    • Once the card pops out, use your finger to pull the card completely out of the SD card slot.
  3. Nextbook NX008HD8G Back Panel Replacement: adım 3, 3 resimden 1. Nextbook NX008HD8G Back Panel Replacement: adım 3, 3 resimden 2. Nextbook NX008HD8G Back Panel Replacement: adım 3, 3 resimden 3.
    • Remove the 5 mm screw using the Phillips PH00 bit in the iFixit metal Screwdriver.
  4. Nextbook NX008HD8G Back Panel Replacement: adım 4, 3 resimden 1. Nextbook NX008HD8G Back Panel Replacement: adım 4, 3 resimden 2. Nextbook NX008HD8G Back Panel Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to separate the back panel by carefully sliding the narrow end of the tool between the front glass and back panel.
    • Use a second plastic opening tool to help pry the front glass from the back panel.
    • You will hear some cracking sounds when separating the front glass from the back panel. That is okay! That is the back panel latches releasing the front glass.
  5. Nextbook NX008HD8G Back Panel Replacement: adım 5, 2 resimden 1. Nextbook NX008HD8G Back Panel Replacement: adım 5, 2 resimden 2.
    • Use your hands to completely separate the rest of the front glass from the back panel.
    • Do not to pull the device apart with too much force. If you do, you may break or bend the back panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Philip Gai
777 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 10-15, Williams Fall 2015 Baylor, Team 10-15, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S10G15
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 912
