Ana içeriğe geç
Nextbook NXA8QC116B Display Assembly Replacement
Neye ihtiyacın var
    1. Nextbook NXA8QC116B Display Assembly Replacement, Battery: adım 1, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement, Battery: adım 1, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement, Battery: adım 1, 3 resimden 3.
      • If you see any leakage coming from the tablet do not open the back cover!
      • Ensure you do not pry around the buttons. This could result in damage and render them inoperable.
      • •With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook NXA8QC116B Display Assembly Replacement: adım 2, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 2, 2 resimden 2.
      • Continue working the spudger downward and pry with the spudger until the bottom left-hand corner of the tablet is reached.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook NXA8QC116B Display Assembly Replacement: adım 3, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 3, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 3, 3 resimden 3.
      • Along the bottom of the tablet, keep using a working and prying motion with the spudger to loosen the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Nextbook NXA8QC116B Display Assembly Replacement: adım 4, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 4, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 4, 3 resimden 3.
      • Continue prying motion until the bottom right-hand corner of the tablet is reached.
      FixBot'a Sor
      Yorum Ekle
    5. Nextbook NXA8QC116B Display Assembly Replacement: adım 5, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 5, 2 resimden 2.
      • Work the spudger to the upper left-hand corner of the tablet.
      FixBot'a Sor
      Yorum Ekle
    6. Nextbook NXA8QC116B Display Assembly Replacement: adım 6, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 6, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 6, 3 resimden 3.
      • Be careful once you get to the top of the tablet with the spudger so as not to damage the headphone jack and other ports.
      • When prying along the top of the tablet, try to keep the spudger between 70 to 85 degrees (almost perpendicular) to the tablet screen.
      • Continue working the spudger around the tablet until the cover of the device comes off
      FixBot'a Sor
      Yorum Ekle
    7. Nextbook NXA8QC116B Display Assembly Replacement: adım 7, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 7, 2 resimden 2.
      • Separate from the cover from the tablet.
      FixBot'a Sor
      Yorum Ekle
    8. Nextbook NXA8QC116B Display Assembly Replacement: adım 8, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 8, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 8, 3 resimden 3.
      • Locate and carefully remove the yellow cellophane tape from the red and black speaker wires that connect the speaker to the edge of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    9. Nextbook NXA8QC116B Display Assembly Replacement: adım 9, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 9, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Locate and carefully remove the yellow cellophane tape with tweezers from the battery connector and black and red speaker wires on the edge of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    10. Nextbook NXA8QC116B Display Assembly Replacement: adım 10, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 10, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 10, 3 resimden 3.
      • Using small pliers, carefully disconnect the male battery connector from the motherboard.
      • If you are only replacing the front camera, skip to step 17 in the camera replacement guide and continue.
      FixBot'a Sor
      Yorum Ekle
    11. Nextbook NXA8QC116B Display Assembly Replacement: adım 11, 1 resimden 1.
      • If the battery is leaking or bulging, stop and get away from it!
      • Carefully remove the gray square pad glued to both the white ribbon cable and the battery by pulling slowly.
      FixBot'a Sor
      Yorum Ekle
    12. Nextbook NXA8QC116B Display Assembly Replacement: adım 12, 1 resimden 1.
      • Locate the white ribbon cable Zero Insertion Force (ZIF) connector between the battery and the motherboard, and peel the yellow cellophane tape off the connector.
      FixBot'a Sor
      Yorum Ekle
    13. Nextbook NXA8QC116B Display Assembly Replacement: adım 13, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 13, 2 resimden 2.
      • Flip up the gray retainer clip on the white ribbon cable ZIF connector on the motherboard with your fingernail. If you do not have fingernails long enough, carefully use a black plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    14. Nextbook NXA8QC116B Display Assembly Replacement: adım 14, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 14, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 14, 3 resimden 3.
      • Remove the white ribbon cable and carefully peel it off the battery.
      FixBot'a Sor
      Yorum Ekle
    15. Nextbook NXA8QC116B Display Assembly Replacement: adım 15, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 15, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 15, 3 resimden 3.
      • Move the spudger in a left-to-right scraping motion to loosen the glue until the battery is separated from the tablet.
      FixBot'a Sor
      Yorum Ekle
    16. Nextbook NXA8QC116B Display Assembly Replacement: adım 16, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook NXA8QC116B Display Assembly Replacement, Motherboard: adım 17, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement, Motherboard: adım 17, 2 resimden 2.
      • Locate and remove the yellow cellophane tape from the display assembly ribbon cable ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook NXA8QC116B Display Assembly Replacement: adım 18, 1 resimden 1.
      • Locate the volume, power, home button ribbon cable ZIF connector.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook NXA8QC116B Display Assembly Replacement: adım 19, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 19, 2 resimden 2.
      • Flip the ZIF connector retainer up with your fingernail. If you do not have fingernails long enough, carefully use the black plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Nextbook NXA8QC116B Display Assembly Replacement: adım 20, 1 resimden 1.
      • Remove the ribbon cable by gently pulling on it.
      FixBot'a Sor
      Yorum Ekle
    5. Nextbook NXA8QC116B Display Assembly Replacement: adım 21, 1 resimden 1.
      • Locate the Display Assembly ribbon cable ZIF connector, and using tweezers, remove the yellow cellophane tape.
      FixBot'a Sor
      Yorum Ekle
    6. Nextbook NXA8QC116B Display Assembly Replacement: adım 22, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 22, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 22, 3 resimden 3.
      • Put your fingernail under the gray ZIF connector retainer and flip the retainer up. If you do not have fingernails long enough, carefully use a black plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    7. Nextbook NXA8QC116B Display Assembly Replacement: adım 23, 1 resimden 1.
      • Remove the Display Assembly ribbon cable by gently pulling on it.
      FixBot'a Sor
      Yorum Ekle
    8. Nextbook NXA8QC116B Display Assembly Replacement: adım 24, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 24, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 24, 3 resimden 3.
      • Use small pliers to pull the connector, wiggling it a little as you pull it from its connection.
      FixBot'a Sor
      Yorum Ekle
    9. Nextbook NXA8QC116B Display Assembly Replacement: adım 25, 2 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 25, 2 resimden 2.
      • Using a J00 screwdriver, remove the 4 black 4.0 mm screws.
      • There is no screw at this location.
      FixBot'a Sor
      Yorum Ekle
    10. Nextbook NXA8QC116B Display Assembly Replacement: adım 26, 1 resimden 1.
      • Locate the ZIF connector to remove the white ribbon cable
      FixBot'a Sor
      Yorum Ekle
    11. Nextbook NXA8QC116B Display Assembly Replacement: adım 27, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 27, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 27, 3 resimden 3.
      • To remove the white ribbon cable, put your fingernail under the gray ZIF connector retainer and flip the retainer up.
      FixBot'a Sor
      Yorum Ekle
    12. Nextbook NXA8QC116B Display Assembly Replacement: adım 28, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement: adım 28, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement: adım 28, 3 resimden 3.
      • Ensure the ribbon cable does not get caught when removing the motherboard. Damage to the ribbon cable may result.
      • Pull the motherboard back over the copper tape to tear the tape and remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
    13. Nextbook NXA8QC116B Display Assembly Replacement: adım 29, 1 resimden 1.
      • Remove the remaining copper tape from the back of the display assembly and the motherboard.
      • Replace with new tape when reassembling.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook NXA8QC116B Display Assembly Replacement, Display Assembly: adım 30, 3 resimden 1. Nextbook NXA8QC116B Display Assembly Replacement, Display Assembly: adım 30, 3 resimden 2. Nextbook NXA8QC116B Display Assembly Replacement, Display Assembly: adım 30, 3 resimden 3.
      • Locate and remove the 3 black 4.0 mm screws on the speaker panel using a J00 screwdriver.
      • Disconnect the speaker from the motherboard.
      • Remove the panel.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook NXA8QC116B Display Assembly Replacement: adım 31, 1 resimden 1.
      • Display Assembly
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Would these instructions be the same for a Nextbook ares11a?
Susann - Yanıt Paylaş
I would think so, it's basically the same adaptation for all laptops.
Rosalina Reyes - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 1,651
