Ana içeriğe geç
Nextplay NP109CR Speakers Replacement
Neye ihtiyacın var
  1. Nextplay NP109CR Speakers Replacement, Speakers: adım 1, 1 resimden 1.
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: adım 2, 1 resimden 1.
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: adım 3, 1 resimden 1.
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: adım 4, 1 resimden 1.
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: adım 5, 1 resimden 1.
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: adım 6, 1 resimden 1.
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: adım 7, 1 resimden 1.
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: adım 8, 1 resimden 1.
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: adım 9, 1 resimden 1.
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: adım 10, 1 resimden 1.
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: adım 11, 1 resimden 1.
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Sonuç
Michelle Read
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G50
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 10
Her zaman: 400
