Ana içeriğe geç
Nexus 10 Display Replacement
Neye ihtiyacın var
    1. Nexus 10 Display Replacement, Battery: adım 1, 3 resimden 1. Nexus 10 Display Replacement, Battery: adım 1, 3 resimden 2. Nexus 10 Display Replacement, Battery: adım 1, 3 resimden 3.
      • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 10 Display Replacement: adım 2, 1 resimden 1.
      • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Nexus 10 Display Replacement: adım 3, 3 resimden 1. Nexus 10 Display Replacement: adım 3, 3 resimden 2. Nexus 10 Display Replacement: adım 3, 3 resimden 3.
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      FixBot'a Sor
      Yorum Ekle
    4. Nexus 10 Display Replacement: adım 4, 3 resimden 1. Nexus 10 Display Replacement: adım 4, 3 resimden 2. Nexus 10 Display Replacement: adım 4, 3 resimden 3.
      • Detach the three connector ribbons passing over the battery using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    5. Nexus 10 Display Replacement: adım 5, 1 resimden 1.
      • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Nexus 10 Display Replacement: adım 6, 2 resimden 1. Nexus 10 Display Replacement: adım 6, 2 resimden 2.
      • Disconnect the battery by lifting it upward and pulling it away from the connector.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus 10 Display Replacement, Headphone Jack: adım 7, 1 resimden 1.
      • Remove one screw on the logic board with a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 10 Display Replacement: adım 8, 3 resimden 1. Nexus 10 Display Replacement: adım 8, 3 resimden 2. Nexus 10 Display Replacement: adım 8, 3 resimden 3.
      • Disconnect right speaker connector ribbon from logic board.
      • Lift the speaker out by pulling up on its corner.
      FixBot'a Sor
      Yorum Ekle
    3. Nexus 10 Display Replacement: adım 9, 3 resimden 1. Nexus 10 Display Replacement: adım 9, 3 resimden 2. Nexus 10 Display Replacement: adım 9, 3 resimden 3.
      • Disconnect connectors around the perimeter of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Nexus 10 Display Replacement: adım 10, 2 resimden 1. Nexus 10 Display Replacement: adım 10, 2 resimden 2.
      • Remove motherboard by gently pulling upward under its corner.
      FixBot'a Sor
      Yorum Ekle
    5. Nexus 10 Display Replacement: adım 11, 1 resimden 1.
      • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Nexus 10 Display Replacement: adım 12, 2 resimden 1. Nexus 10 Display Replacement: adım 12, 2 resimden 2.
      • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
      FixBot'a Sor
      Yorum Ekle
    7. Nexus 10 Display Replacement: adım 13, 2 resimden 1. Nexus 10 Display Replacement: adım 13, 2 resimden 2.
      • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
      FixBot'a Sor
      Yorum Ekle
    8. Nexus 10 Display Replacement: adım 14, 2 resimden 1. Nexus 10 Display Replacement: adım 14, 2 resimden 2.
      • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus 10 Display Replacement, Display: adım 15, 2 resimden 1. Nexus 10 Display Replacement, Display: adım 15, 2 resimden 2.
      • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 10 Display Replacement: adım 16, 2 resimden 1. Nexus 10 Display Replacement: adım 16, 2 resimden 2.
      • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
      • Remove the board by tilting it forward and pulling outward.
      FixBot'a Sor
      Yorum Ekle
    3. Nexus 10 Display Replacement: adım 17, 1 resimden 1.
      • Remove second speaker by gently tilting and pulling upward.
      FixBot'a Sor
      Yorum Ekle
    4. Nexus 10 Display Replacement: adım 18, 3 resimden 1. Nexus 10 Display Replacement: adım 18, 3 resimden 2. Nexus 10 Display Replacement: adım 18, 3 resimden 3.
      • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
      • Remove the connector by liberally applying upward pressure.
      FixBot'a Sor
      Yorum Ekle
    5. Nexus 10 Display Replacement: adım 19, 3 resimden 1. Nexus 10 Display Replacement: adım 19, 3 resimden 2. Nexus 10 Display Replacement: adım 19, 3 resimden 3.
      • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
      • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Benjamin Troller
2.239 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G18
4 Üyeler
4Kılavuz Yorumları
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - Yanıt Paylaş
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol - Yanıt Paylaş
Still waiting to see how the screen is remove
Frank - Yanıt Paylaş
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 9,161
