Ana içeriğe geç
Nexus 10 Front Facing Camera Replacement
Neye ihtiyacın var
    1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: adım 1, 3 resimden 1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: adım 1, 3 resimden 2. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: adım 1, 3 resimden 3.
      • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 10 Front Facing Camera Replacement: adım 2, 3 resimden 1. Nexus 10 Front Facing Camera Replacement: adım 2, 3 resimden 2. Nexus 10 Front Facing Camera Replacement: adım 2, 3 resimden 3.
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      FixBot'a Sor
      Yorum Ekle
    3. Nexus 10 Front Facing Camera Replacement: adım 3, 3 resimden 1. Nexus 10 Front Facing Camera Replacement: adım 3, 3 resimden 2. Nexus 10 Front Facing Camera Replacement: adım 3, 3 resimden 3.
      • Lift latch on front-facing camera connector.
      • Pull the connector toward the top of the device and remove the front-facing camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Benjamin Troller
2.239 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G18
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 64
Her zaman: 1,001
