Ana içeriğe geç
Nexus 10 Headphone Jack Replacement
Neye ihtiyacın var
  1. Nexus 10 Headphone Jack Replacement, Battery: adım 1, 3 resimden 1. Nexus 10 Headphone Jack Replacement, Battery: adım 1, 3 resimden 2. Nexus 10 Headphone Jack Replacement, Battery: adım 1, 3 resimden 3.
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Headphone Jack Replacement: adım 3, 3 resimden 1. Nexus 10 Headphone Jack Replacement: adım 3, 3 resimden 2. Nexus 10 Headphone Jack Replacement: adım 3, 3 resimden 3.
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Headphone Jack Replacement: adım 4, 3 resimden 1. Nexus 10 Headphone Jack Replacement: adım 4, 3 resimden 2. Nexus 10 Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Headphone Jack Replacement: adım 5, 1 resimden 1.
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Headphone Jack Replacement: adım 6, 2 resimden 1. Nexus 10 Headphone Jack Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Headphone Jack Replacement, Headphone Jack: adım 7, 1 resimden 1.
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Headphone Jack Replacement: adım 8, 3 resimden 1. Nexus 10 Headphone Jack Replacement: adım 8, 3 resimden 2. Nexus 10 Headphone Jack Replacement: adım 8, 3 resimden 3.
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Headphone Jack Replacement: adım 9, 3 resimden 1. Nexus 10 Headphone Jack Replacement: adım 9, 3 resimden 2. Nexus 10 Headphone Jack Replacement: adım 9, 3 resimden 3.
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Headphone Jack Replacement: adım 10, 2 resimden 1. Nexus 10 Headphone Jack Replacement: adım 10, 2 resimden 2.
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Headphone Jack Replacement: adım 11, 1 resimden 1.
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Headphone Jack Replacement: adım 12, 2 resimden 1. Nexus 10 Headphone Jack Replacement: adım 12, 2 resimden 2.
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Headphone Jack Replacement: adım 13, 2 resimden 1. Nexus 10 Headphone Jack Replacement: adım 13, 2 resimden 2.
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Headphone Jack Replacement: adım 14, 2 resimden 1. Nexus 10 Headphone Jack Replacement: adım 14, 2 resimden 2.
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
Sonuç
Benjamin Troller
2.239 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G18
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 70
Her zaman: 1,053
