Ana içeriğe geç
Nexus 10 USB Port Replacement
Neye ihtiyacın var
  1. Nexus 10 USB Port Replacement, Battery: adım 1, 3 resimden 1. Nexus 10 USB Port Replacement, Battery: adım 1, 3 resimden 2. Nexus 10 USB Port Replacement, Battery: adım 1, 3 resimden 3.
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 USB Port Replacement: adım 2, 1 resimden 1.
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 USB Port Replacement: adım 3, 3 resimden 1. Nexus 10 USB Port Replacement: adım 3, 3 resimden 2. Nexus 10 USB Port Replacement: adım 3, 3 resimden 3.
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
    Be carefull with the power button cable. Don’t insert the plastic tool in this zone
    Jesus Garcia - Yanıt
    Some instruction guides also suggest optional use of a suction cup with which to tug on the glass while separating the plastic backing. I found this helpful. Also, if you have a spudger of more rigid plastic, use that one here. My blue spudgers got chewed up pretty badly during this process.
    Jim - Yanıt
    I found that the top right (looking at the screen) doesn’t have any corner clips, just a metal antenna (?), so it is easiest to get this corner popped first and then work your way around. The bottom corners have clips which are tough to undo.
    Jeremy R - Yanıt
  4. Nexus 10 USB Port Replacement: adım 4, 3 resimden 1. Nexus 10 USB Port Replacement: adım 4, 3 resimden 2. Nexus 10 USB Port Replacement: adım 4, 3 resimden 3.
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
    The left two connectors flip up from the cable side. The right connector flips up from opposite the cable.
    Glenn Davis - Yanıt
    Note that you don’t just pull the ribbons out. There is a clamp on each connector that needs to be prised opened, releasing the ribbon. This was helpful: https://youtu.be/yru4k62qdEU?t=302
    Royston Shufflebotham - Yanıt
    You sir, are a true humanitarian!!!
    Harold Gue - Yanıt
  5. Nexus 10 USB Port Replacement: adım 5, 1 resimden 1.
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 USB Port Replacement: adım 6, 2 resimden 1. Nexus 10 USB Port Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
    When reassembling reconnect the data ribbon cables first, then connect the battery connection last so that you’re not plugging in data lines while powered. Ideally you’d disconnect the battery first but that’s a bit hard with the design so you just have to try to ensure it’s switched off first.
    Andrew Whalan - Yanıt
    Excellent with video
    Jim Scott - Yanıt
  7. Nexus 10 USB Port Replacement, Headphone Jack: adım 7, 1 resimden 1.
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 USB Port Replacement: adım 8, 3 resimden 1. Nexus 10 USB Port Replacement: adım 8, 3 resimden 2. Nexus 10 USB Port Replacement: adım 8, 3 resimden 3.
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 USB Port Replacement: adım 9, 3 resimden 1. Nexus 10 USB Port Replacement: adım 9, 3 resimden 2. Nexus 10 USB Port Replacement: adım 9, 3 resimden 3.
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 USB Port Replacement: adım 10, 2 resimden 1. Nexus 10 USB Port Replacement: adım 10, 2 resimden 2.
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 USB Port Replacement: adım 11, 1 resimden 1.
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 USB Port Replacement: adım 12, 2 resimden 1. Nexus 10 USB Port Replacement: adım 12, 2 resimden 2.
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
    Expect some resistance when prying up on the vibration motor. There was some aggressive double sided tape under it and it was stuck pretty firmly.
    Jim - Yanıt
  13. Nexus 10 USB Port Replacement: adım 13, 2 resimden 1. Nexus 10 USB Port Replacement: adım 13, 2 resimden 2.
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 USB Port Replacement: adım 14, 2 resimden 1. Nexus 10 USB Port Replacement: adım 14, 2 resimden 2.
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Benjamin Troller
2.181 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G18
4 Üyeler
Bir Yorum
Perfect guide, I managed to fix my Nexus 10 broken usb port.
It may be worth to mention after step 14 you need to gently remove the plastic connectors cover and place it on the replacement part.
Mauri - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 5,584
