Ana içeriğe geç
Nexus 4 Audio Jack Replacement
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  1. Nexus 4 Audio Jack Replacement: adım 3, 3 resimden 1. Nexus 4 Audio Jack Replacement: adım 3, 3 resimden 2. Nexus 4 Audio Jack Replacement: adım 3, 3 resimden 3.
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  2. Nexus 4 Audio Jack Replacement, Battery: adım 4, 2 resimden 1. Nexus 4 Audio Jack Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  3. Nexus 4 Audio Jack Replacement, Plastic Midframe: adım 6, 3 resimden 1. Nexus 4 Audio Jack Replacement, Plastic Midframe: adım 6, 3 resimden 2. Nexus 4 Audio Jack Replacement, Plastic Midframe: adım 6, 3 resimden 3.
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  4. Nexus 4 Audio Jack Replacement, Audio Jack: adım 7, 3 resimden 1. Nexus 4 Audio Jack Replacement, Audio Jack: adım 7, 3 resimden 2. Nexus 4 Audio Jack Replacement, Audio Jack: adım 7, 3 resimden 3.
    • Using a spudger, pop off the gray connector on the top right of the motherboard.
  5. Nexus 4 Audio Jack Replacement: adım 8, 3 resimden 1. Nexus 4 Audio Jack Replacement: adım 8, 3 resimden 2. Nexus 4 Audio Jack Replacement: adım 8, 3 resimden 3.
    • Gently lift the audio jack upwards and to the left to remove it from the motherboard.
  6. Nexus 4 Audio Jack Replacement: adım 9, 2 resimden 1. Nexus 4 Audio Jack Replacement: adım 9, 2 resimden 2.
    • The audio port will likely lift out together with the ambient light sensor rubber cap.
    • Remove the cap from the old part and move it to the new one. Ensure the cap stays in place when installing the new audio port into the phone.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Kaitlyn Jones
4.952 İtibar
8 adet Kılavuz yazıldı
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G32
4 Üyeler
One Comment
where can I order the original connector on my Nexus 4? With delivery to the Crimea.
Grateful for the answer in advance.
Konstantin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 13
Her zaman: 22,885
