Ana içeriğe geç
Nexus 4 Camera Replacement
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  1. Nexus 4 Camera Replacement: adım 3, 3 resimden 1. Nexus 4 Camera Replacement: adım 3, 3 resimden 2. Nexus 4 Camera Replacement: adım 3, 3 resimden 3.
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  2. Nexus 4 Camera Replacement, Battery: adım 4, 2 resimden 1. Nexus 4 Camera Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  3. Nexus 4 Camera Replacement, Plastic Midframe: adım 6, 3 resimden 1. Nexus 4 Camera Replacement, Plastic Midframe: adım 6, 3 resimden 2. Nexus 4 Camera Replacement, Plastic Midframe: adım 6, 3 resimden 3.
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  4. Nexus 4 Camera Replacement, Camera: adım 7, 3 resimden 1. Nexus 4 Camera Replacement, Camera: adım 7, 3 resimden 2. Nexus 4 Camera Replacement, Camera: adım 7, 3 resimden 3.
    • Gently pry the metal tab up using a spudger, and lift up the disconnected black flap.
  5. Nexus 4 Camera Replacement: adım 8, 3 resimden 1. Nexus 4 Camera Replacement: adım 8, 3 resimden 2. Nexus 4 Camera Replacement: adım 8, 3 resimden 3.
    • With a spudger, carefully pry up the black tab connecting the camera to the motherboard.
    • Lift up the camera from the socket.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kaitlyn Jones
4.952 İtibar
8 adet Kılavuz yazıldı
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G32
4 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 7,773
