Ana içeriğe geç
Nexus 4 Speaker Replacement
Neye ihtiyacın var
    1. Nexus 4 Speaker Replacement, Back Cover: adım 1, 2 resimden 1. Nexus 4 Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
      Bu adımda kullanılan alet:
      SIM Card Eject Tool
      $2.99
      • Power off the phone, by long-pressing the power button and touching Power off.
      • Remove the SIM tray using the SIM Card Eject Tool.
      • This step is required in order to remove the back case.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 4 Speaker Replacement: adım 2, 1 resimden 1.
      T5 Torx Screwdriver
      $5.49
      FixBot'a Sor
      Yorum Ekle
    3. Nexus 4 Speaker Replacement: adım 3, 3 resimden 1. Nexus 4 Speaker Replacement: adım 3, 3 resimden 2. Nexus 4 Speaker Replacement: adım 3, 3 resimden 3.
      • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
      • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus 4 Speaker Replacement, Battery: adım 4, 2 resimden 1. Nexus 4 Speaker Replacement, Battery: adım 4, 2 resimden 2.
      • Remove the two 1.8 mm Phillips screws holding down the battery connector.
      • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 4 Speaker Replacement, Battery removal: adım 5, 2 resimden 1. Nexus 4 Speaker Replacement, Battery removal: adım 5, 2 resimden 2.
      Plastic Cards
      $2.99
      • Remove the blue tape that secures the white antenna cable to the battery.
      • Using a spudger, carefully disconnect the white antenna cable.
      • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
      • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
      • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus 4 Speaker Replacement, Speaker: adım 6, 2 resimden 1. Nexus 4 Speaker Replacement, Speaker: adım 6, 2 resimden 2.
      • Remove the two 4.8 mm screws that hold the speaker enclosure together using the Phillips 00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 4 Speaker Replacement: adım 7, 2 resimden 1. Nexus 4 Speaker Replacement: adım 7, 2 resimden 2.
      • Gently pry the speaker up and away from the back of the phone using a plastic opening tool, and lift it out of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Kaitlyn Jones
4.964 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G32
4 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 13,909
