Ana içeriğe geç
Nexus 4 Speaker Replacement
Neye ihtiyacın var
  1. Nexus 4 Speaker Replacement, Back Cover: adım 1, 2 resimden 1. Nexus 4 Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Speaker Replacement: adım 2, 1 resimden 1.
    T5 Torx Screwdriver
    $5.49
  3. Nexus 4 Speaker Replacement: adım 3, 3 resimden 1. Nexus 4 Speaker Replacement: adım 3, 3 resimden 2. Nexus 4 Speaker Replacement: adım 3, 3 resimden 3.
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Speaker Replacement, Battery: adım 4, 2 resimden 1. Nexus 4 Speaker Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Speaker Replacement, Battery removal: adım 5, 2 resimden 1. Nexus 4 Speaker Replacement, Battery removal: adım 5, 2 resimden 2.
    Plastic Cards
    $2.99
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Speaker Replacement, Speaker: adım 6, 2 resimden 1. Nexus 4 Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Remove the two 4.8 mm screws that hold the speaker enclosure together using the Phillips 00 screwdriver.
  7. Nexus 4 Speaker Replacement: adım 7, 2 resimden 1. Nexus 4 Speaker Replacement: adım 7, 2 resimden 2.
    • Gently pry the speaker up and away from the back of the phone using a plastic opening tool, and lift it out of the phone.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Kaitlyn Jones
4.964 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G32
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 13,493
