Ana içeriğe geç
Nexus 5 Antenna Cable Replacement
Neye ihtiyacın var
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: adım 1, 1 resimden 1.
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: adım 2, 3 resimden 1. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: adım 2, 3 resimden 2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: adım 2, 3 resimden 3.
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: adım 3, 2 resimden 1. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: adım 3, 2 resimden 2.
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: adım 4, 3 resimden 1. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: adım 4, 3 resimden 2. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: adım 4, 3 resimden 3.
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: adım 5, 2 resimden 1. Nexus 5 Antenna Cable Replacement, Reassemble the Device: adım 5, 2 resimden 2.
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Tyler Caldwell
184 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S1G1
2 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 2,898
