Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the battery of your Nexus 5.
Neye ihtiyacın var
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Bu adımda kullanılan alet:Spudger$2.99
Use the flat end of a nylon spudger to disconnect the battery connector.
465 farklı kişi bu kılavuzu tamamladı.
66 Yorum
Did it in less than 10 mins..
Already had experience with taking the backcover off...
In the start of the guide it says "Replace the battery in your iPhone 5s"
After battery replacement my wireless charging was not working. Pay attention to settle holding clip in the middle of phone - just firmly press around the "S" from the back of phone until you hear it clicks in.
Thank you so much for this tip! I did it and it worked. Now Wireless charging is working again.
QNZ -
