Giriş
Use this guide to replace the motherboard in your Nexus 5.
Neye ihtiyacın var
Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
Push the tool into the hole until you see the card pop out.
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Bu adımda kullanılan alet:Spudger$2.99
Use the flat end of a nylon spudger to disconnect the battery connector.
31 farklı kişi bu kılavuzu tamamladı.
12Kılavuz Yorumları
is the motherboard from the 32gb nexus 5, compatible for the nexus 5 16gb lcd??
It should be, yes. I've chopped and changed loads of Nexus 5 phone around and haven't had a problem.
Thanks for the repy. My Nexus 5 has some bootoop problems and when i go to the boot options, (the hold power and volume down), it says Lock State - LOCKED. so im thinking of replacing the motherboard. or is there a way to fix my problem? Thanks for the reply. I appreciate it.
I just used this guide to quickly get at the motherboard to replace a faulty power button. It's tedious but not impossible with a very clean soldering iron tip, solder wick, and lots of flux. The replacement button and covers from iFixit were an exact match (I checked under a microscope).
