Ana içeriğe geç
Nexus 5X Rear Panel Replacement
Neye ihtiyacın var
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: adım 1, 3 resimden 1. Nexus 5X Rear Panel Replacement, SIM Card Tray: adım 1, 3 resimden 2. Nexus 5X Rear Panel Replacement, SIM Card Tray: adım 1, 3 resimden 3.
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: adım 2, 3 resimden 1. Nexus 5X Rear Panel Replacement, Rear Panel: adım 2, 3 resimden 2. Nexus 5X Rear Panel Replacement, Rear Panel: adım 2, 3 resimden 3.
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Rear Panel Replacement: adım 3, 3 resimden 1. Nexus 5X Rear Panel Replacement: adım 3, 3 resimden 2. Nexus 5X Rear Panel Replacement: adım 3, 3 resimden 3.
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: adım 4, 2 resimden 1. Nexus 5X Rear Panel Replacement: adım 4, 2 resimden 2.
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
Sonuç
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
246.314 İtibar
682 adet Kılavuz yazıldı
1Rehber Yorum
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 8,934
