Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Nexus 6 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Nexus 6 Teardown, Nexus 6 Teardown: adım 1, 3 resimden 1. Nexus 6 Teardown, Nexus 6 Teardown: adım 1, 3 resimden 2. Nexus 6 Teardown, Nexus 6 Teardown: adım 1, 3 resimden 3.
    • Nexus 6 Tech Specs:
    • 5.96" display with a resolution of 1440 x 2560 pixels (493 ppi)
    • 2.7 GHz Quad core Krait 450 CPU (Qualcomm Snapdragon 805 SOC) + Adreno 420 GPU, with 3 GB RAM
    • 32 or 64 GB of internal storage
    • Android 5.0 Lollipop
    • 802.11ac 2x2 (MIMO) + Bluetooth 4.1 + NFC
    • 3220 mAh "non-removable" battery
    • 13 MP rear-facing camera with Optical Image Stabilization + 2 MP front-facing camera
  2. Nexus 6 Teardown: adım 2, 3 resimden 1. Nexus 6 Teardown: adım 2, 3 resimden 2. Nexus 6 Teardown: adım 2, 3 resimden 3.
    • The Nexus 6 has a central rear-facing camera that looks like it might have some interesting flash action hidden alongside.
    • More on this later...
    • The top of the phone is decked with a 3.5 mm headphone jack and a seemingly out-of-place nano SIM card slot.
    • The bottom houses the Micro USB port, along with the obligatory FCC markings, leaving the back of the phone jargon free.
  3. Nexus 6 Teardown: adım 3, 2 resimden 1. Nexus 6 Teardown: adım 3, 2 resimden 2.
    • Begun, the Clone War has.
    • Three companies produce two phablets and we hold them up in the same hand to compare their size. Thanks to a thinner bezel, you get more screen real estate with the Nexus 6, with only a slightly larger chassis.
    • Nexus 6: 82.98 mm x 159.26 mm x 10.06 mm
    • iPhone 6 Plus: 77.8 mm x 158.1 mm x 7.1 mm
  4. Nexus 6 Teardown: adım 4, 3 resimden 1. Nexus 6 Teardown: adım 4, 3 resimden 2. Nexus 6 Teardown: adım 4, 3 resimden 3.
    • With no visible screws on the rear cover, we resort to opening picks to pry or slide our way in.
    • The bad: No simple clips on this cover, looks like your fingernails won't be enough for this job.
    • The good: The adhesive securing the cover is relatively mild, once the pick sneaks into the seam, the cover can be peeled up.
    • The ugly: Removing the rear cover still doesn't provide access to internal components. At least we now have visual confirmation of screws, a whole legion of them.
  5. Nexus 6 Teardown: adım 5, 3 resimden 1. Nexus 6 Teardown: adım 5, 3 resimden 2. Nexus 6 Teardown: adım 5, 3 resimden 3.
    • Time to take out the (oh-so-many) screws. 22 T3 Torx screws present themselves, and silently await our precision driver.
    • We've spotted a secret door! With a secret connector!
    • We've learned to check for these, and disconnect them in advance, just in case.
    • A shiny copper coil catches our eye through the holey midframe. We'll be sure to investigate that once we get it cracked...
  6. Nexus 6 Teardown: adım 6, 2 resimden 1. Nexus 6 Teardown: adım 6, 2 resimden 2.
    • The Nexus is finally ready to reveal its secrets. Looks like that mystery connector belonged to the battery!
    • With cables decoupled, it's suddenly delightfully apparent why there were so many screws in the midframe. The Nexus 6 practically falls apart into two halves; the midframe/battery assembly, and the display/motherboard assembly.
    • Thanks to loads of screws, we don't have to deal with any adhesive, or even any tricky plastic clips.
  7. Nexus 6 Teardown: adım 7, 2 resimden 1. Nexus 6 Teardown: adım 7, 2 resimden 2.
    • Would you look at that! The shiny copper from before is an inductive charging coil! (Maybe this'll catch on after all).
    • Quick inductive charging refresher: an inductive charging station drives an alternating current through a coil. The current moving back and forth in the base coil generates and collapses a magnetic field, which induces a current flow in the coil in the device. This AC current is then rectified into DC power to charge the battery.
    • Peeling the coil off lets us get a look at the 3.8 V, 3220 mAh (12.2 Wh) battery.
    • That's a step above the iPhone 6 Plus's 11.1 Wh, but it looks like the Nexus battery life doesn't benefit much.
    • For a "non-removable" battery, that wasn't so hard.
  8. Nexus 6 Teardown: adım 8, 2 resimden 1. Nexus 6 Teardown: adım 8, 2 resimden 2.
    • As we continue our trek, we get to investigate that flash assembly a bit closer.
    • The Nexus 6 takes the dual LED flash in a different direction—two different directions, really.
    • The circular camera lens cover acts as a light guide for two flanking LEDs, mimicking a ring flash. Neat!
  9. Nexus 6 Teardown: adım 9, 3 resimden 1. Nexus 6 Teardown: adım 9, 3 resimden 2. Nexus 6 Teardown: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • First peek at the motherboard brings back memories of the Moto X; big, green and lots of tiny EMI shields.
    • We easily pluck out the rear- and front-facing cameras with a pair of tweezers.
    • The Nexus 6 is certainly no slouch when it comes to cameras. The 13 MP rear-facing camera sports a Sony Exmor IMX 214 CMOS image sensor (Also found in the OnePlus One).
    • The Nexus 6 also features optical image stabilization, just like the iPhone 6 Plus, which makes for sharper photos.
  10. Nexus 6 Teardown: adım 10, 2 resimden 1. Nexus 6 Teardown: adım 10, 2 resimden 2.
    • After freeing the motherboard from the display assembly, we spy a lone IC:
    • Atmel MXT640T CCU 1424D TW QLR64 Touchscreen Controller
    • And that's it! The display assembly is bare and free of extra components, after a fairly easy jaunt to the center of the Nexus.
    • Even though it was easy to get here, the display is still fused to the digitizer glass—it won't be a cheap replacement part if you crack your screen.
  11. Nexus 6 Teardown: adım 11, 1 resimden 1.
    • Finally, the part we've all been waiting for! Let's identify some of the ICs that power this Nexus:
    • SK Hynix H9CKNNNDBTMTAR 24 Gb (3 GB) LPDDR3 RAM, with Qualcomm Snapdragon 805 SoC layered underneath
    • Qualcomm PMA8084 Power Management IC
    • SanDisk SDIN9DW4-32G 32 GB eMMC NAND Flash
    • Qualcomm MDM9625M LTE Modem
    • Qualcomm WTR1625L RF Transceiver
    • Qualcomm WFR1620 Receive-Only Companion Chip
    • Texas Instruments TMS320C55 Digital Signal Processor
  12. Nexus 6 Teardown: adım 12, 2 resimden 1. Nexus 6 Teardown: adım 12, 2 resimden 2.
    • Even more ICs:
    • Qualcomm SMB1359
    • Broadcom BCM4356 802.11ac + Bluetooth 4.1 IC
    • RF Micro Devices RF7389EU F14NRC2 Envelope Tracking Power Amplifier
    • Speaker Grille RGB LED
    • For some reason, Motorola decided to keep this LED a secret.
    • NXP TFA9890A Audio Amplifier
    • Qualcomm QFE1100 Envelope Tracking IC
  13. Nexus 6 Teardown: adım 13, 2 resimden 1. Nexus 6 Teardown: adım 13, 2 resimden 2.
    Rotary Tool
    $49.99
    • But wait there's more! Motorola is touting its Turbo Charger, boasting enough charge for 6 hours of use in just 15 minutes of charging.
    • Compatible with Qualcomm's new Quick Charge 2.0 tech, the Motorola Turbo Charger lists three different output options: 5 V at 1.6 A, 9 V at 1.6 A, and 12 V at 1.2 A.
    • Sounds like there's nothing snailish about this Turbo, but really there's only one way to find out...
    • ...And that's by slicing our way in with a rotary tool!
  14. Nexus 6 Teardown: adım 14, 2 resimden 1. Nexus 6 Teardown: adım 14, 2 resimden 2.
    • On the one side, amidst wads of epoxy, we find a transformer surrounded by some plain jane capacitors, voltage regulators, and a USB port.
    • On the other side, amid a sea of solder and surface mount components:
    • A bridge rectifier, responsible for converting AC to DC
    • Dialogue iW1760B Power Supply Controller, clearly the brains of the operation
  15. Nexus 6 Teardown: adım 15, 2 resimden 1. Nexus 6 Teardown: adım 15, 2 resimden 2.
    • Motorola Nexus 6 Repairability Score: 7 out of 10 (10 is easiest to repair).
    • Pressure contacts and cable connectors make the modular components (cameras, buttons, headphone jack) easy to replace.
    • The Nexus 6 uses a single kind of screw, although it's a fairly uncommon size (T3).
    • Many many screws hold the midframe in place—this makes its removal somewhat tedious, but also means no clips or adhesive are needed to secure it to the front panel.
    • The glued-in battery is less accessible than we'd like, but it can be replaced.
    • Several components (vibrator, SIM slot, speaker, USB port) are soldered directly to the motherboard and will be more difficult to replace than if they were connected by cable.
    • The digitizer is fused to the display, increasing repair costs for a cracked screen, but it is easy to get to the bare display assembly.
42Kılavuz Yorumları
Step 12, the chip above the orange one, Broadcom BCM20795 NFC controller chip.
Frank Chen - Yanıt Paylaş
So is it possible to put back the back cover or it need some kind of glue ?
th3d3vi0us - Yanıt Paylaş
It's still pretty sticky, so it ought to go back on and stay without any additional adhesive.
Andrew Optimus Goldheart - Paylaş
I'm struggling to stick mine back on, what adhesive can I use?
Zaidoun Haddad - Paylaş
Is it possible to upgrade to upgrade the storage?
Collin Corcoran - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 71
Son 30 gün: 344
Her zaman: 250,789
