Ana içeriğe geç
Nexus 6P Display Replacement
Neye ihtiyacın var
  1. Nexus 6P Display Replacement, Back Cover: adım 1, 3 resimden 1. Nexus 6P Display Replacement, Back Cover: adım 1, 3 resimden 2. Nexus 6P Display Replacement, Back Cover: adım 1, 3 resimden 3.
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. Nexus 6P Display Replacement: adım 2, 3 resimden 1. Nexus 6P Display Replacement: adım 2, 3 resimden 2. Nexus 6P Display Replacement: adım 2, 3 resimden 3.
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Nexus 6P Display Replacement: adım 3, 2 resimden 1. Nexus 6P Display Replacement: adım 3, 2 resimden 2.
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Nexus 6P Display Replacement: adım 4, 3 resimden 1. Nexus 6P Display Replacement: adım 4, 3 resimden 2. Nexus 6P Display Replacement: adım 4, 3 resimden 3.
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Nexus 6P Display Replacement: adım 5, 3 resimden 1. Nexus 6P Display Replacement: adım 5, 3 resimden 2. Nexus 6P Display Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  6. Nexus 6P Display Replacement: adım 6, 3 resimden 1. Nexus 6P Display Replacement: adım 6, 3 resimden 2. Nexus 6P Display Replacement: adım 6, 3 resimden 3.
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
  7. Nexus 6P Display Replacement, Battery: adım 7, 2 resimden 1. Nexus 6P Display Replacement, Battery: adım 7, 2 resimden 2.
    • Unscrew the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
  8. Nexus 6P Display Replacement: adım 8, 3 resimden 1. Nexus 6P Display Replacement: adım 8, 3 resimden 2. Nexus 6P Display Replacement: adım 8, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the three flex cables.
  9. Nexus 6P Display Replacement: adım 9, 2 resimden 1. Nexus 6P Display Replacement: adım 9, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the interconnect cable from the daughterboard.
    • Use an iOpener to loosen the adhesive under the battery.
  10. Nexus 6P Display Replacement: adım 10, 3 resimden 1. Nexus 6P Display Replacement: adım 10, 3 resimden 2. Nexus 6P Display Replacement: adım 10, 3 resimden 3.
    Plastic Cards
    $2.99
    • Warning: do not insert the spudger or plastic card too deep underneath the battery. The display cable runs underneath the battery.
    • Scroll down to the next step to see where the cable is.
    • Insert the flat end of a spudger as deep as the notch and carefully slide along the edge to cut the adhesive…
    • Use a plastic card to cut the remaining adhesive on the left side underneath the battery.
  11. Nexus 6P Display Replacement: adım 11, 1 resimden 1.
    • Remove the battery.
  12. Nexus 6P Display Replacement, Display: adım 12, 3 resimden 1. Nexus 6P Display Replacement, Display: adım 12, 3 resimden 2. Nexus 6P Display Replacement, Display: adım 12, 3 resimden 3.
    • Remove the two Philipps #000 screws.
    • Remove the metal plate.
    • Use the flat end of a spudger to disconnect the display flex cable.
  13. Nexus 6P Display Replacement: adım 13, 1 resimden 1.
  14. Nexus 6P Display Replacement: adım 14, 3 resimden 1. Nexus 6P Display Replacement: adım 14, 3 resimden 2. Nexus 6P Display Replacement: adım 14, 3 resimden 3.
    • Work an iFlex opening tool between the display and the midframe to create a gap.
    • Insert an opening pick into the gap and carefully slide it to the top right corner.
    • Insert a second opening pick and move it to the top left corner.
  15. Nexus 6P Display Replacement: adım 15, 2 resimden 1. Nexus 6P Display Replacement: adım 15, 2 resimden 2.
    • Slide the opening pick from the top left corner down the left side of the smartphone to the bottom left corner.
  16. Nexus 6P Display Replacement: adım 16, 3 resimden 1. Nexus 6P Display Replacement: adım 16, 3 resimden 2. Nexus 6P Display Replacement: adım 16, 3 resimden 3.
    • If the adhesive felt hard to cut, reheat it with your iOpener.
    • Slide the opening pick from the top right around the corner and down along the side to the lower right.
    • Move it around the corner and towards the charging port to separate the rest of the adhesive.
  17. Nexus 6P Display Replacement: adım 17, 2 resimden 1. Nexus 6P Display Replacement: adım 17, 2 resimden 2.
    • When all the adhesive is cut, separate the display from the midframe at the top of the phone.
    • Thread the display flex cable through the gap in the midframe.
    • Remove the display.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
23 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
247.614 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.758 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 12,365
