Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Nexus 6P cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Nexus 6P Teardown, Nexus 6P Teardown: adım 1, 2 resimden 1. Nexus 6P Teardown, Nexus 6P Teardown: adım 1, 2 resimden 2.
    • Now that we've (un)wrapped up the opening act, it's time for the main event! Here's what Google has to say about its latest Android flagship:
    • Qualcomm Snapdragon 810 v2.1, 2.0 GHz octa-core 64-bit processor with Adreno 430 GPU
    • 12.3 MP/4K rear-facing camera with laser-assisted autofocus and electronic image stabilization, 8 MP front-facing camera
    • 5.7” WQHD 2560 × 1440 (518 ppi) AMOLED display
    • 3 GB LPDDR4 RAM with 32 GB, 64 GB, or 128 GB of internal storage
    • USB Type-C Port
    • Nexus Imprint fingerprint reader and Android Sensor Hub
    • Android 6.0 Marshmallow
  2. Nexus 6P Teardown: adım 2, 3 resimden 1. Nexus 6P Teardown: adım 2, 3 resimden 2. Nexus 6P Teardown: adım 2, 3 resimden 3.
    • The all-metal, aeronautical-grade anodized aluminum chassis is another first for a Nexus device.
    • We're fairly certain that the 6P isn't designed to function as a ramp for your Tech Deck.
    • The raised camera mesa is apparently Huawei's strategy for squeezing a 4K camera into the new phone. Or, like us, they could just be obsessed with mesas.
    • Coming in for a closer look, we see that the glass lens cover slopes to a smooth curve at either end. Fancy!
  3. Nexus 6P Teardown: adım 3, 3 resimden 1. Nexus 6P Teardown: adım 3, 3 resimden 2. Nexus 6P Teardown: adım 3, 3 resimden 3.
    • Compared with its fraternal twin, the Nexus 5X (top), the 6P shines through with its Wide Quad HD AMOLED display.
    • Just for fun, we also line up the 6P next to ye olde Nexus 6. With its nearly identical footprint, you get triple bonus points if you can tell which is which!
    • The 6P is slimmer, at 7.3 mm, versus 10.06 mm on the Nexus 6. It also shaves off 6 grams, coming in at 178 g. (For comparison, the iPhone 6s Plus tips the scales at 192 g.)
    • For those who were wondering, yes, it doubles as an external battery pack. So when your 5X runs low on juice, just grab your 6P and a umbilical USB-C cable and you'll be good to go!
    • No word yet on what happens if you umbilical two 6Ps that are both at 50% power. We assume they'll both charge to 100%. Perpetual power, solved.
  4. Nexus 6P Teardown: adım 4, 3 resimden 1. Nexus 6P Teardown: adım 4, 3 resimden 2. Nexus 6P Teardown: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    iOpener
    $19.99
    Satın Al
    • Like the Nexus 6, there are no visible screws on the rear cover. Unlike the Nexus 6, this is a unibody device, so there won't be any handy peel-off rear cover.
    • The 6P's smooth enclosure is broken only by this small, suspicious plastic panel at the bottom. Let's pile a hot iOpener on it and see what's inside.
    • With enough heat, the panel is easily pried and peeled off, exposing four screws.
    • Including one covered with a tamper evident seal. If this is your first visit to iFixit, check out our Repair Manifesto to see what we think about things like that.
  5. Nexus 6P Teardown: adım 5, 3 resimden 1. Nexus 6P Teardown: adım 5, 3 resimden 2. Nexus 6P Teardown: adım 5, 3 resimden 3.
    iSclack
    $24.99
    Satın Al
    • Getting to the screws under the plastic cover wasn't too hard, but signs now point to screws under the camera mesa cover too...
    • The panel in question is made of tight-fitting, easily shattered, glass. Removing this won't be any fun at all.
    • We were pleasantly surprised by the easy opening procedure and minimal adhesive of the 5X. We had hoped this trend would include the 6P—it seems that in the Nexus family, blood doesn't run as thick as glue.
    • The ultra-tight fit renders our plastic tools useless—we resort to a curved razor blade, safety glasses, and prayers.
    • Several frustrating minutes later, we are able to deploy the iSclack, and pop the phone out of its rear enclosure.
  6. Nexus 6P Teardown: adım 6, 3 resimden 1. Nexus 6P Teardown: adım 6, 3 resimden 2. Nexus 6P Teardown: adım 6, 3 resimden 3.
    • With the initial adhesive adventures behind us, the 6P has finally come out of its shell.
    • Unlike other phones we've seen lately, there's no discrete display assembly or easily removed rear cover here. Instead, the 6P's internals come out of the rear case in one mega-sized component assembly, leaving only the NFC antenna behind.
    • This isn't a good sign for the 6P's repairability—in fact, it reminds us of our harrowing experience with the HTC One M7.
    • On the bright side, it looks like a daughterboard interconnect cable is all that stands between us and the battery!
  7. Nexus 6P Teardown: adım 7, 3 resimden 1. Nexus 6P Teardown: adım 7, 3 resimden 2. Nexus 6P Teardown: adım 7, 3 resimden 3.
    • The battery is a monster—and, it's fiercely glued in. But at least we didn't have to dig too far to get here.
    • This super-sized, 3.82 V, 13.18 Wh lithium-poly cell weighs in at a rated capacity of 3450 mAh.
    • For those of you keeping score, this powerhouse is rated at 230 mAh more than the cell we found in the original Nexus 6 and 700 mAh more than the battery in the iPhone 6s Plus.
  8. Nexus 6P Teardown: adım 8, 3 resimden 1. Nexus 6P Teardown: adım 8, 3 resimden 2. Nexus 6P Teardown: adım 8, 3 resimden 3.
    • Next up, we pull out one of the smallest daughterboards we've ever seen. It's only a little more than a simple USB-C board.
    • After that harrowing opening procedure, it's nice to see one repairability win in the 6P vs 5X comparison: a USB port mounted on a small and inexpensive daughterboard, rather than soldered onto the motherboard.
    • The front side of the daughterboard features some control hardware and spring contacts for the LTE antenna...
    • Texas Instruments TUSB320 USB type-C port controller
    • AKM Semiconductor AK8789 hall sensor
    • Skyworks SKYxxxx antenna tuner (likely)
    • ...And on the back we spy one of the 6P's three noise canceling microphones and a couple more contacts, for the vibrating motor and speaker.
  9. Nexus 6P Teardown: adım 9, 3 resimden 1. Nexus 6P Teardown: adım 9, 3 resimden 2. Nexus 6P Teardown: adım 9, 3 resimden 3.
    • We continue our sleuthing along the bottom of the phone and come across what appears to be a speaker box.
    • Front-facing speakers are becoming a bit of a trademark for Google, and were found in last year's Nexus 9 and the Nexus 6.
    • We suspect Google's motive for including these front-facing speakers is simple enough: people prefer speakers that face them.
    • Of course that says nothing about how it actually sounds. We'll have to wait until we put our 6P back together to give it a listen.
  10. Nexus 6P Teardown: adım 10, 3 resimden 1. Nexus 6P Teardown: adım 10, 3 resimden 2. Nexus 6P Teardown: adım 10, 3 resimden 3.
    • Next to fly free is the headphone jack, which we find encased in a little rubber sleeve. Hmmm.
    • While we've been watching carefully for signs of life waterproofing, this small sleeve alone doesn't indicate whether Google might be preparing for rising tides.
    • Moving along, we pull out the front-facing (i.e. selfie) camera. This 8 MP, ƒ/2.4 camera is up 3 MP from its counterpart on the 5X, but still maintains the same 1.4 micron pixel size.
    • We snap a few photos of our new-found peripheral friends and head for the core.
  11. Nexus 6P Teardown: adım 11, 2 resimden 1. Nexus 6P Teardown: adım 11, 2 resimden 2.
    • Most of the peripherals are out of the way, allowing us to focus on the motherboard—glue-free and topped off with a glob of bubblegum thermal paste, just the way we like it.
    • Well, this is awkward. Although the front-facing camera didn't put up much of a fight, it appears the main camera is soldered in place.
  12. Nexus 6P Teardown: adım 12, 2 resimden 1. Nexus 6P Teardown: adım 12, 2 resimden 2.
    • . . . Or not!
    • While you do have to remove the motherboard to access the main camera, it turns out that only the camera bracket is soldered to the board. The camera itself is easily disconnected and removed.
    • This 12.3 MP camera features the same Sony IMX377 image sensor and ƒ/2.0 lens as found in the 5X, but thanks to the boost in processing power from the Snapdragon 810, the 6P can take advantage of an EIS (electronic image stabilization) algorithm, and shoot slow-mo video at up to 240 fps.
  13. Nexus 6P Teardown: adım 13, 3 resimden 1. Nexus 6P Teardown: adım 13, 3 resimden 2. Nexus 6P Teardown: adım 13, 3 resimden 3.
    • Spudger ready, we turn our attention to the square Nexus Imprint sensor.
    • Wait. Square? Wasn't this thing round when we first saw it?
    • It turns out this version of the Imprint sensor is quite different from the one we found in the 5X. The circular profile of this fingerprint reader is solely due to the round hole in the 6P's rear case.
    • Perhaps Huawei is planning to use this very fingerprint reader in one of their other phones. Handy.
    • Fingerprints FPC1020 fingerprint sensor
    • Fingerprints FPC2050 fingerprint controller (likely)
  14. Nexus 6P Teardown: adım 14, 1 resimden 1.
    • We smell chips! With the motherboard free and the EMI shielding pulled away, it's time for a look at the silicon:
    • Micron MT53B384M64D4NK-062 3 GB LPDDR4 RAM, layered over Qualcomm Snapdragon 810 v2.1, 2.0 GHz octa-core 64-bit CPU
    • Samsung KLMBG4GEND-B031 32 GB eMMC 5.0 NAND flash
    • Qualcomm PMI8994 power management IC (found in many 2015 Android smartphones including the Nexus 5X)
    • Qualcomm SMB1351 Quick Charge IC (Likely an iteration of SMB1358 found in the Nexus 5X)
    • Qualcomm QFE1100 envelope tracking IC
    • ST Microelectronics STM32F411CE 32-bit 100 MHz ARM Cortex-M4 RISC microcontroller
    • Maxim Integrated MAX98925 audio amplifier
  15. Nexus 6P Teardown: adım 15, 1 resimden 1.
    • The back of the motherboard is brimming with even more control hardware:
    • Broadcom BCM4358 5G WiFi 802.11ac client
    • Qualcomm PM8994 power management IC (as seen in the Nexus 5X and HTC One M9)
    • NXP PN548 NFC controller
    • Qualcomm WCD9330 audio codec
    • Qualcomm WTR3925 RF transceiver
    • RF Microdevices RF1891 antenna switch module
    • Skyworks SKY77814-11 power amplifier module for LTE
  16. Nexus 6P Teardown: adım 16, 2 resimden 1. Nexus 6P Teardown: adım 16, 2 resimden 2.
    • IC Identifications, pt. 2:
    • ON Semiconductor FAN53526UC89X 3.0 A step-down switching regulator
    • Texas Instruments display power supply (likely)
    • Texas Instruments TLV62084 step-down converter
    • Texas Instruments TPS61256A boost converter
    • Texas Instruments INA231 output current/voltage/power monitor
    • ON Semiconductor NLAS2750 dual SPDT analog switch and NCN1154 DP3T analog switch
    • Texas Instruments LMV7275 comparator
  17. Nexus 6P Teardown: adım 17, 2 resimden 1. Nexus 6P Teardown: adım 17, 2 resimden 2.
    • IC Identification, pt. 3:
    • Qorvo (formerly TriQuint) RF8117V RF power amplifier
    • Qorvo (formerly RF Micro Devices) RF7302 and RF7305 power amplifier module
    • Skyworks SKY15203 antenna switch
    • Skyworks SKY85608-11 5-Ghz, 802.11ac switch and low noise amplifier (likely)
    • NXP Semiconductor BGU80x9 GPS/GLONASS/Galileo/COMPASS LNA
  18. Nexus 6P Teardown: adım 18, 2 resimden 1. Nexus 6P Teardown: adım 18, 2 resimden 2.
    • IC Identification, pt. 4 (sensors):
    • Bosch Sensortec BMI160 3-axis accelerometer/gyroscope
    • Bosch Sensortec BMP280 pressure sensor
    • AMS TMD27723 ambient light sensor
  19. Nexus 6P Teardown: adım 19, 2 resimden 1. Nexus 6P Teardown: adım 19, 2 resimden 2.
    • Nexus 6P Repairability Score: 2 out of 10 (10 is easiest to repair)
    • Solid external construction improves durability.
    • Once the arduous opening procedure is complete, the battery is immediately accessible.
    • It's very difficult—although not impossible—to open the device without damaging the glass camera cover. Because of the unibody design, this makes every component extremely difficult to replace.
    • The display assembly cannot be replaced without tunneling through the entire phone. This makes one of the most common repairs, a damaged screen, difficult to accomplish.
    • Tough adhesive holds the rear cover panels and battery in place.
Geoff Wacker
89.961 İtibar
89 adet Kılavuz yazıldı
48 Yorum
For step 7, don't know if anyone has noticed the typo... You say the nexus 6p has 700mAh more battery than the iphone 6s... 6s has ~1750mAh and the 6p has 3450 mAh... That's almost double the battery size (1700 mAh difference). Just a stickler for an order of magnitude :D Thanks for the great teardown, sad to see the 6p isn't easily repaired...
ErictheMaker - Yanıt
We're actually comparing the battery in the Nexus 6P to the battery in the 6s Plus, not the 6s. The 6s Plus has a 2750 mAh battery :)
Andrew Optimus Goldheart -
At least the battery is not "smaller than promised" like iPhone
John Stead - Yanıt
The battery is Li-Po and not Li-ion tech which is more safer and lasts longer. I'd rather have the iPhone battery still. Lasts just as long in my experience.
Jake -
Li-Po means Li-polymer.Li-Po is included in Li-ion, which means lithium batteries.iPhone's batteries are the same Li-Po batteries,they're just written Li-ion.
Atom Zhang -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 75
Her zaman: 286,173
