Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide is for the removal of the daughterboard. The daughterboard contains the Micro USB port.
Neye ihtiyacın var
Power down your device.
Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
Insert the plastic opening tool under the side edge of the battery connector, and gently pry upward to disconnect it.
Use the flat end of a spudger or your fingernail to flip up the clear protective flap on the ribbon cable ZIF socket.
Using the flat end of a spudger or your fingernail, flip up the thin portion of the connector (the white part, opposite of the side where the cable inserts) to release the cable from its socket.
Slide the cable out of the ZIF socket.
Remove the gray seal covering the top center screw on the daughterboard.
46 farklı kişi bu kılavuzu tamamladı.
11 Yorum
Hi,
I need to replace USB connector on my Nexus7-2013 wifi, buit I had see on ASUS web site, if I change this spart, i need to recalibrate the unit .http://www.asusparts.eu/fr/Asus-90NK0080...
Is it true ?
Thx for your answer
According to these repair stories, it worked fine without any mentions of a need to calibrate: Nexus 7 (2nd Gen Wi-Fi) LCD Board
Hello i have a problem with a spudger in the daughter board, i crashed one of them will replacing the screen, i need to know how to fix it or the best place to buy a used daughter board
