Ana içeriğe geç
Nexus 7 Speaker Assembly Replacement
Neye ihtiyacın var
  1. Nexus 7 Speaker Assembly Replacement, Rear Panel: adım 1, 1 resimden 1.
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Nexus 7 Speaker Assembly Replacement: adım 2, 2 resimden 1. Nexus 7 Speaker Assembly Replacement: adım 2, 2 resimden 2.
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Nexus 7 Speaker Assembly Replacement: adım 3, 3 resimden 1. Nexus 7 Speaker Assembly Replacement: adım 3, 3 resimden 2. Nexus 7 Speaker Assembly Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 Speaker Assembly Replacement: adım 4, 3 resimden 1. Nexus 7 Speaker Assembly Replacement: adım 4, 3 resimden 2. Nexus 7 Speaker Assembly Replacement: adım 4, 3 resimden 3.
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 Speaker Assembly Replacement: adım 5, 2 resimden 1. Nexus 7 Speaker Assembly Replacement: adım 5, 2 resimden 2.
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Nexus 7 Speaker Assembly Replacement, Battery Cable: adım 6, 2 resimden 1. Nexus 7 Speaker Assembly Replacement, Battery Cable: adım 6, 2 resimden 2.
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
  7. Nexus 7 Speaker Assembly Replacement, Speaker Cable: adım 7, 1 resimden 1.
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
  8. Nexus 7 Speaker Assembly Replacement: adım 8, 1 resimden 1.
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
  9. Nexus 7 Speaker Assembly Replacement, Speaker Assembly: adım 9, 1 resimden 1.
    • Remove the following screws securing the speaker assembly to the display assembly:
    • Two 4.25 mm black Phillips screws
    • One 3.2 mm silver Phillips screw
  10. Nexus 7 Speaker Assembly Replacement: adım 10, 1 resimden 1.
    • Lift and remove the speaker assembly out of the Nexus 7.
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
Hello. My Nexus 7 had issue with the speaker but I can't return it because i don't live in the USA. Can you tell me where can I buy speaker for the Nexus 7. Thanks.
bobski - Yanıt
Bobski, if you're not covered under warranty then you'll have to buy the speaker assembly on your own, from eBay or a third party site. They're kind of rare.
EXCELLENT guide, had no issues replacing mine and works great! Thanks iFixit!
Justin Redd - Yanıt
Would anyone happen to know the type of connector that is used to connect the nexus 7's speaker to its logic board?
Gray - Yanıt
Guide was great! Worked perfectly. Thank you!
milleniumofthecomet88 - Yanıt
easy took like 5minutes
David - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 63
Her zaman: 26,847
