Ana içeriğe geç
Nexus 9 Antenna Board Replacement
Görüntüleme: 2,1 B
İstatistikleri görüntüle:
Son 24 Saat:
2
Son 7 Gün:
27
Son 30 Gün:
104
Her zaman:
2.111
Yorumlar: 7
7 comments on steps.
Tamamlandı: 0
Hiç kimse bu kılavuzu "tamamlandı" olarak işaretlemedi. İlk mi olacaksın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: Tahmin yok
Zorluk: Orta
Use this guide to replace the antenna board on your Nexus 9.
Neye ihtiyacın var
Parçalar
Aletler
    1. Nexus 9 Antenna Board Replacement, Rear Case: adım 1, 3 resimden 1. Nexus 9 Antenna Board Replacement, Rear Case: adım 1, 3 resimden 2. Nexus 9 Antenna Board Replacement, Rear Case: adım 1, 3 resimden 3.
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus 9 Antenna Board Replacement, Antenna Board: adım 2, 2 resimden 1. Nexus 9 Antenna Board Replacement, Antenna Board: adım 2, 2 resimden 2.
      • This step is not necessary if you have already removed the battery.
      • Carefully peel up the copper shielding with your fingers.
      • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus 9 Antenna Board Replacement: adım 3, 1 resimden 1.
      • Unscrew the three 3 mm Torx T5 screws on the antenna board.
      • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
      FixBot'a Sor
      Yorum Ekle
    3. Nexus 9 Antenna Board Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
      • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
      • The antenna board should now lift free of the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Yazar
ile
Geoff Wacker
93.172 İtibar
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 27
Son 30 gün: 104
Her zaman: 2,111
