Ana içeriğe geç
Nexus 9 Front Facing Camera Replacement
Neye ihtiyacın var
  1. Nexus 9 Front Facing Camera Replacement, Rear Case: adım 1, 3 resimden 1. Nexus 9 Front Facing Camera Replacement, Rear Case: adım 1, 3 resimden 2. Nexus 9 Front Facing Camera Replacement, Rear Case: adım 1, 3 resimden 3.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Front Facing Camera Replacement, Front Facing Camera: adım 2, 1 resimden 1.
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
89.953 İtibar
89 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 752
