Ana içeriğe geç
Nexus 9 Vibrator Daughterboard Replacement
Neye ihtiyacın var
  1. Nexus 9 Vibrator Daughterboard Replacement, Rear Case: adım 1, 3 resimden 1. Nexus 9 Vibrator Daughterboard Replacement, Rear Case: adım 1, 3 resimden 2. Nexus 9 Vibrator Daughterboard Replacement, Rear Case: adım 1, 3 resimden 3.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Vibrator Daughterboard Replacement, Vibrator Daughterboard: adım 2, 1 resimden 1.
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 Vibrator Daughterboard Replacement: adım 3, 2 resimden 1. Nexus 9 Vibrator Daughterboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 Vibrator Daughterboard Replacement: adım 4, 3 resimden 1. Nexus 9 Vibrator Daughterboard Replacement: adım 4, 3 resimden 2. Nexus 9 Vibrator Daughterboard Replacement: adım 4, 3 resimden 3.
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 Vibrator Daughterboard Replacement: adım 5, 1 resimden 1.
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
Sonuç
Geoff Wacker
89.956 İtibar
89 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 336
