Ana içeriğe geç
Nexus 9 Vibrator Replacement
Neye ihtiyacın var
  1. Nexus 9 Vibrator Replacement, Rear Case: adım 1, 3 resimden 1. Nexus 9 Vibrator Replacement, Rear Case: adım 1, 3 resimden 2. Nexus 9 Vibrator Replacement, Rear Case: adım 1, 3 resimden 3.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
    FixBot'a Sor
  2. Nexus 9 Vibrator Replacement, Vibrator Daughterboard: adım 2, 1 resimden 1.
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
    FixBot'a Sor
  3. Nexus 9 Vibrator Replacement: adım 3, 2 resimden 1. Nexus 9 Vibrator Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
    FixBot'a Sor
  4. Nexus 9 Vibrator Replacement: adım 4, 3 resimden 1. Nexus 9 Vibrator Replacement: adım 4, 3 resimden 2. Nexus 9 Vibrator Replacement: adım 4, 3 resimden 3.
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
    FixBot'a Sor
  5. Nexus 9 Vibrator Replacement: adım 5, 1 resimden 1.
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
    FixBot'a Sor
  6. Nexus 9 Vibrator Replacement, Vibrator: adım 6, 2 resimden 1. Nexus 9 Vibrator Replacement, Vibrator: adım 6, 2 resimden 2.
    • Use a pair of tweezers to remove the vibrator from the device.
    FixBot'a Sor
Sonuç
Geoff Wacker
92.717 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 61
Her zaman: 553
