Ana içeriğe geç
Nexus One Antenna Housing Replacement
Neye ihtiyacın var
  1. Nexus One Antenna Housing Replacement, Lower Cover: adım 1, 2 resimden 1. Nexus One Antenna Housing Replacement, Lower Cover: adım 1, 2 resimden 2.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Nexus One Antenna Housing Replacement, Antenna Housing: adım 2, 1 resimden 1.
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Niklas Johnson
1.207 İtibar
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 3,728
