Ana içeriğe geç
Nexus One Camera Replacement
Neye ihtiyacın var
    1. Nexus One Camera Replacement, Rear Cover: adım 1, 2 resimden 1. Nexus One Camera Replacement, Rear Cover: adım 1, 2 resimden 2.
      • Using two fingers, push up on the rear cover.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus One Camera Replacement: adım 2, 1 resimden 1.
      • The rear cover slides up and off.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus One Camera Replacement, Battery: adım 3, 1 resimden 1.
      • Using the plastic opening tools, pry the left bottom corner of the battery up.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus One Camera Replacement: adım 4, 1 resimden 1.
      • Pull the battery up and out.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus One Camera Replacement, Battery Housing: adım 5, 1 resimden 1.
      • Remove the two Torx T5 screws.
      • Remove the one Philips #00 screw.
      FixBot'a Sor
      Yorum Ekle
    2. Nexus One Camera Replacement: adım 6, 2 resimden 1. Nexus One Camera Replacement: adım 6, 2 resimden 2.
      • Using the plastic opening tool, pry up the battery housing upwards.
      • Push pry tool down, undoing the plastic tab.
      FixBot'a Sor
      Yorum Ekle
    3. Nexus One Camera Replacement: adım 7, 2 resimden 1. Nexus One Camera Replacement: adım 7, 2 resimden 2.
      • Pry the upper left tab open on the battery housing.
      FixBot'a Sor
      Yorum Ekle
    4. Nexus One Camera Replacement: adım 8, 2 resimden 1. Nexus One Camera Replacement: adım 8, 2 resimden 2.
      • Pry the top tab of the battery housing.
      FixBot'a Sor
      Yorum Ekle
    5. Nexus One Camera Replacement: adım 9, 2 resimden 1. Nexus One Camera Replacement: adım 9, 2 resimden 2.
      • Pry the right side tab of the battery housing.
      FixBot'a Sor
      Yorum Ekle
    6. Nexus One Camera Replacement: adım 10, 2 resimden 1. Nexus One Camera Replacement: adım 10, 2 resimden 2.
      • Pull up on the battery housing.
      • Slide the battery housing out to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Nexus One Camera Replacement, Camera: adım 11, 3 resimden 1. Nexus One Camera Replacement, Camera: adım 11, 3 resimden 2. Nexus One Camera Replacement, Camera: adım 11, 3 resimden 3.
      • Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip)
      • Swap the spudger to the other side of the cover base. Pry upwards. (fix?)
      • Grasp the camera module and pull up.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Niklas Johnson
1.207 İtibar
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 3,824
