Ana içeriğe geç
Nexus One Flash Replacement
Neye ihtiyacın var
  1. Nexus One Flash Replacement, Rear Cover: adım 1, 2 resimden 1. Nexus One Flash Replacement, Rear Cover: adım 1, 2 resimden 2.
    • Using two fingers, push up on the rear cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nexus One Flash Replacement: adım 2, 1 resimden 1.
    • The rear cover slides up and off.
    FixBot'a Sor
    Yorum Ekle
  3. Nexus One Flash Replacement, Battery: adım 3, 1 resimden 1.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
    FixBot'a Sor
    Yorum Ekle
  4. Nexus One Flash Replacement: adım 4, 1 resimden 1.
    • Pull the battery up and out.
    FixBot'a Sor
    Yorum Ekle
  5. Nexus One Flash Replacement, Battery Housing: adım 5, 1 resimden 1.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
    FixBot'a Sor
    Yorum Ekle
  6. Nexus One Flash Replacement: adım 6, 2 resimden 1. Nexus One Flash Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
    FixBot'a Sor
    Yorum Ekle
  7. Nexus One Flash Replacement: adım 7, 2 resimden 1. Nexus One Flash Replacement: adım 7, 2 resimden 2.
    • Pry the upper left tab open on the battery housing.
    FixBot'a Sor
    Yorum Ekle
  8. Nexus One Flash Replacement: adım 8, 2 resimden 1. Nexus One Flash Replacement: adım 8, 2 resimden 2.
    • Pry the top tab of the battery housing.
    FixBot'a Sor
    Yorum Ekle
  9. Nexus One Flash Replacement: adım 9, 2 resimden 1. Nexus One Flash Replacement: adım 9, 2 resimden 2.
    • Pry the right side tab of the battery housing.
    FixBot'a Sor
    Yorum Ekle
  10. Nexus One Flash Replacement: adım 10, 2 resimden 1. Nexus One Flash Replacement: adım 10, 2 resimden 2.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
    FixBot'a Sor
    Yorum Ekle
  11. Nexus One Flash Replacement, Flash: adım 11, 1 resimden 1.
    • Insert the spudger under the bottom of the flash board
    • Twist the spudger to lift and release the flash board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Niklas Johnson
1.207 İtibar
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 2,103
