Neye ihtiyacın var
Using the plastic opening tools, pry the left bottom corner of the battery up.
Using the plastic opening tool, push the blade into the space between the case and lower cover.
Turn the opening tool slightly, the lower cover will detach on that side.
Repeat on other side of the seam.
The lower cover will slide off.
Remove the one T5 Torx screw
Remove the one #00 Philips screw
Lift up the end of the antenna housing and slide it outwards.
Using the spudger, pry upwards on the second microphone connector.
Insert the spudger under the connector.
Push the spudger up and twist to release the connector.
Repeat for the next connector.
Bir başkası bu kılavuzu tamamladı.
