Ana içeriğe geç
Nexus One SIM Card Tray Replacement
Neye ihtiyacın var
  1. Nexus One SIM Card Tray Replacement, Rear Cover: adım 1, 2 resimden 1. Nexus One SIM Card Tray Replacement, Rear Cover: adım 1, 2 resimden 2.
    • Using two fingers, push up on the rear cover.
  2. Nexus One SIM Card Tray Replacement: adım 2, 1 resimden 1.
    • The rear cover slides up and off.
  3. Nexus One SIM Card Tray Replacement, Battery: adım 3, 1 resimden 1.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One SIM Card Tray Replacement: adım 4, 1 resimden 1.
    • Pull the battery up and out.
  5. Nexus One SIM Card Tray Replacement, Battery Housing: adım 5, 1 resimden 1.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One SIM Card Tray Replacement: adım 6, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One SIM Card Tray Replacement: adım 7, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 7, 2 resimden 2.
    • Pry the upper left tab open on the battery housing.
  8. Nexus One SIM Card Tray Replacement: adım 8, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 8, 2 resimden 2.
    • Pry the top tab of the battery housing.
  9. Nexus One SIM Card Tray Replacement: adım 9, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 9, 2 resimden 2.
    • Pry the right side tab of the battery housing.
  10. Nexus One SIM Card Tray Replacement: adım 10, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 10, 2 resimden 2.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One SIM Card Tray Replacement, Lower Cover: adım 11, 2 resimden 1. Nexus One SIM Card Tray Replacement, Lower Cover: adım 11, 2 resimden 2.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  12. Nexus One SIM Card Tray Replacement, Antenna Housing: adım 12, 1 resimden 1.
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
  13. Nexus One SIM Card Tray Replacement, Motherboards: adım 13, 2 resimden 1. Nexus One SIM Card Tray Replacement, Motherboards: adım 13, 2 resimden 2.
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  14. Nexus One SIM Card Tray Replacement: adım 14, 3 resimden 1. Nexus One SIM Card Tray Replacement: adım 14, 3 resimden 2. Nexus One SIM Card Tray Replacement: adım 14, 3 resimden 3.
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  15. Nexus One SIM Card Tray Replacement: adım 15, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 15, 2 resimden 2.
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  16. Nexus One SIM Card Tray Replacement: adım 16, 3 resimden 1. Nexus One SIM Card Tray Replacement: adım 16, 3 resimden 2. Nexus One SIM Card Tray Replacement: adım 16, 3 resimden 3.
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  17. Nexus One SIM Card Tray Replacement: adım 17, 1 resimden 1.
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  18. Nexus One SIM Card Tray Replacement: adım 18, 1 resimden 1.
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  19. Nexus One SIM Card Tray Replacement: adım 19, 3 resimden 1. Nexus One SIM Card Tray Replacement: adım 19, 3 resimden 2. Nexus One SIM Card Tray Replacement: adım 19, 3 resimden 3.
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
  20. Nexus One SIM Card Tray Replacement, Upper Motherboard: adım 20, 2 resimden 1. Nexus One SIM Card Tray Replacement, Upper Motherboard: adım 20, 2 resimden 2.
    • Using the spudger, lift the blue colored connector.
    • Use the supdger to lift the black connetor up as well.
    • Detach the upper motherboard from the lower motherboard.
  21. Nexus One SIM Card Tray Replacement, SIM Card Tray: adım 21, 1 resimden 1.
    • Use the spudger to lift the SIM card tray connector off the motherboard.
  22. Nexus One SIM Card Tray Replacement: adım 22, 2 resimden 1. Nexus One SIM Card Tray Replacement: adım 22, 2 resimden 2.
    • Use the spudger to lift the SIM tray board off the motherboard.
    • The SIM Tray hinges up, it is still connected by the copper tape.
    • add picture of SIM tray flipped over the side to complete guide.
Sonuç
Niklas Johnson
1.207 İtibar
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 3,947
