Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
  3. Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Pull the battery up and out.
    • Pull the battery up and out.
  5. Remove the two Torx T5 screws.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
    • Pry the upper left tab open on the battery housing.
  8. Pry the top tab of the battery housing. Pry the top tab of the battery housing.
    • Pry the top tab of the battery housing.
  9. Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
    • Pry the right side tab of the battery housing.
  10. Pull up on the battery housing. Slide the battery housing out to remove it.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Using the spudger, pry upwards on the second microphone connector. Using the spudger, pry upwards on the second microphone connector.
    • Using the spudger, pry upwards on the second microphone connector.
  12. Pull up on the ribbon cable, the tape will detach from the main board ribbon.
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Sonuç
Niklas Johnson
1.117 İtibar
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,186
