Ana içeriğe geç
Nexus One Vibrator Replacement
Neye ihtiyacın var
  1. Nexus One Vibrator Replacement, Lower Cover: adım 1, 2 resimden 1. Nexus One Vibrator Replacement, Lower Cover: adım 1, 2 resimden 2.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
    FixBot'a Sor
    Yorum Ekle
  2. Nexus One Vibrator Replacement, Antenna Housing: adım 2, 1 resimden 1.
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
    FixBot'a Sor
    Yorum Ekle
    • The vibrator is located on the back of the antenna housing.
    • Use the spudger to pry up on the axle of the motor.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Niklas Johnson
1.207 İtibar
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 1,844
