Ana içeriğe geç
Nexus Q Inner Dome Daughterboard Replacement
Neye ihtiyacın var
  1. Nexus Q Inner Dome Daughterboard Replacement, Taoglas PU18 Wi-Fi Dual Band Antenna: adım 1, 1 resimden 1.
    • Squeeze and pull to pop the cap off of the Nexus Q.
  2. Nexus Q Inner Dome Daughterboard Replacement: adım 2, 2 resimden 1. Nexus Q Inner Dome Daughterboard Replacement: adım 2, 2 resimden 2.
    • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
    • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  3. Nexus Q Inner Dome Daughterboard Replacement, Inner Dome Daughterboard: adım 3, 1 resimden 1.
    • Undo the ZIF connector by prying with a spudger.
  4. Nexus Q Inner Dome Daughterboard Replacement: adım 4, 1 resimden 1.
    • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  5. Nexus Q Inner Dome Daughterboard Replacement: adım 5, 1 resimden 1.
    • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  6. Nexus Q Inner Dome Daughterboard Replacement: adım 6, 1 resimden 1.
    • Use a spudger to disconnect the daughterboard from the ZIF connector.
Sonuç
Alex Thomas
27 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-10, Maness Winter 2013 Cal Poly, Team 7-10, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G10
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 52
Her zaman: 1,149
