Giriş
Use this guide to replace the battery.
Neye ihtiyacın var
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
Remove the battery from the Nexus S.
12 farklı kişi bu kılavuzu tamamladı.
