Giriş
This guide will help you replace the rear facing camera.
Neye ihtiyacın var
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
Remove the battery from the Nexus S.
Use your thumb to slide the SIM card downwards from the SIM card slot.
Remove the SIM card.
Remove the six Phillips screws securing the rear inner frame to the inner case.
Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
7 farklı kişi bu kılavuzu tamamladı.
