Ana içeriğe geç
Nexus S Rear Inner Frame Replacement
Neye ihtiyacın var
  1. Nexus S Rear Inner Frame Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Rear Inner Frame Replacement: adım 2, 1 resimden 1.
    • Remove the rear panel from the Nexus S.
  3. Nexus S Rear Inner Frame Replacement, Battery: adım 3, 1 resimden 1.
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Rear Inner Frame Replacement, SIM Card: adım 4, 2 resimden 1. Nexus S Rear Inner Frame Replacement, SIM Card: adım 4, 2 resimden 2.
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Rear Inner Frame Replacement, Rear Inner Frame: adım 5, 1 resimden 1.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Rear Inner Frame Replacement: adım 6, 1 resimden 1.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Rear Inner Frame Replacement: adım 7, 2 resimden 1. Nexus S Rear Inner Frame Replacement: adım 7, 2 resimden 2.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Rear Inner Frame Replacement: adım 8, 2 resimden 1. Nexus S Rear Inner Frame Replacement: adım 8, 2 resimden 2.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Rear Inner Frame Replacement: adım 9, 1 resimden 1.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Rear Inner Frame Replacement: adım 10, 1 resimden 1.
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Rear Inner Frame Replacement, Rear Inner Frame: adım 11, 1 resimden 1.
    • Rear inner frame remains.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,137
