Ana içeriğe geç
Nexus S SIM Card Board Replacement
Neye ihtiyacın var
  1. Nexus S SIM Card Board Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S SIM Card Board Replacement: adım 2, 1 resimden 1.
    • Remove the rear panel from the Nexus S.
  3. Nexus S SIM Card Board Replacement, Battery: adım 3, 1 resimden 1.
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S SIM Card Board Replacement, SIM Card: adım 4, 2 resimden 1. Nexus S SIM Card Board Replacement, SIM Card: adım 4, 2 resimden 2.
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S SIM Card Board Replacement, Rear Inner Frame: adım 5, 1 resimden 1.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S SIM Card Board Replacement: adım 6, 1 resimden 1.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S SIM Card Board Replacement: adım 7, 2 resimden 1. Nexus S SIM Card Board Replacement: adım 7, 2 resimden 2.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S SIM Card Board Replacement: adım 8, 2 resimden 1. Nexus S SIM Card Board Replacement: adım 8, 2 resimden 2.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S SIM Card Board Replacement: adım 9, 1 resimden 1.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S SIM Card Board Replacement: adım 10, 1 resimden 1.
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S SIM Card Board Replacement, SIM Card Board: adım 11, 1 resimden 1.
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Nexus S SIM Card Board Replacement: adım 12, 3 resimden 1. Nexus S SIM Card Board Replacement: adım 12, 3 resimden 2. Nexus S SIM Card Board Replacement: adım 12, 3 resimden 3.
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Nexus S SIM Card Board Replacement: adım 13, 1 resimden 1.
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Nexus S SIM Card Board Replacement, SIM Card Board: adım 14, 1 resimden 1.
    • SIM Card board remains.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Where can I buy this part ? (Nexus S SIM Card Board ) ?
Andre Venancio - Yanıt
고액토토먹튀검증 완료 . 고액토토 환전 책임지고 먹튀검증 해드립니다. 소액부터 고액까지 안전이 제일우선 먹튀타임즈에서 함께하세요
timesjs01 - Yanıt
I simply want to mention I am very new to blogging and seriously savored this web page. Likely I’m going to bookmark your blog post . You amazingly come with fantastic writings. Appreciate it for revealing your blog. 먹튀검증업체
먹튀타임즈에서 먹튀검증업체를 여러분께 추천드립니다
모두 직접 연락이 가능한 안전한 먹튀검증업체입니다.
timesjs01 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 8,956
