Ana içeriğe geç
Nike+ Sportband Screen Replacement
Neye ihtiyacın var
  1. Nike+ Sportband Screen Replacement, External Case: adım 1, 2 resimden 1. Nike+ Sportband Screen Replacement, External Case: adım 1, 2 resimden 2.
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Screen Replacement: adım 2, 2 resimden 1. Nike+ Sportband Screen Replacement: adım 2, 2 resimden 2.
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Screen Replacement, Screen: adım 3, 2 resimden 1. Nike+ Sportband Screen Replacement, Screen: adım 3, 2 resimden 2.
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Screen Replacement: adım 4, 3 resimden 1. Nike+ Sportband Screen Replacement: adım 4, 3 resimden 2. Nike+ Sportband Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Screen Replacement: adım 5, 2 resimden 1. Nike+ Sportband Screen Replacement: adım 5, 2 resimden 2.
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Screen Replacement: adım 6, 3 resimden 1. Nike+ Sportband Screen Replacement: adım 6, 3 resimden 2. Nike+ Sportband Screen Replacement: adım 6, 3 resimden 3.
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
Sonuç
Daniel Burtner
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 9-9, Wilson Spring 2016 IUPUI, Team 9-9, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S9G9
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 256
