Ana içeriğe geç
Nike SportWatch GPS Back Panel Replacement
Neye ihtiyacın var
    1. Nike SportWatch GPS Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
      • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nike SportWatch GPS Back Panel Replacement: adım 2, 1 resimden 1.
      • Carefully separate the watch by pulling the band away from the main board.
      FixBot'a Sor
      Yorum Ekle
    3. Nike SportWatch GPS Back Panel Replacement: adım 3, 1 resimden 1.
      • Pry the black plastic piece above the battery out using a nylon or metal spudger.
      • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
      FixBot'a Sor
      Yorum Ekle
    4. Nike SportWatch GPS Back Panel Replacement: adım 4, 1 resimden 1.
      • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
      FixBot'a Sor
      Yorum Ekle
    5. Nike SportWatch GPS Back Panel Replacement: adım 5, 1 resimden 1.
      • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ian Eichorn
696 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G8
3 Üyeler
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can I find a new watch band?
rhalljr68 - Yanıt Paylaş
You can´t. Nike left us alone
Leonardo Cartier - Yanıt Paylaş
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 2,937
