Ana içeriğe geç
Nike SportWatch GPS Front Panel Replacement
Neye ihtiyacın var
  1. Nike SportWatch GPS Front Panel Replacement, Front Panel: adım 1, 1 resimden 1.
    • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Front Panel Replacement: adım 2, 1 resimden 1.
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Front Panel Replacement: adım 3, 1 resimden 1.
    • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS Front Panel Replacement: adım 4, 1 resimden 1.
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
  5. Nike SportWatch GPS Front Panel Replacement: adım 5, 1 resimden 1.
    • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
    • If you are unfamiliar with this tool use the iOpener guide here
  6. Nike SportWatch GPS Front Panel Replacement: adım 6, 1 resimden 1.
    • Push the panel out from the back of the screen, using your fingers.
Sonuç
Ian Eichorn
678 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G8
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where I can find the replacement glass? regards
Erick Sobreiro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,258
