Giriş
Sometimes the only thing wrong with your camera is a broken button that won't let you turn it on. This guide will show you how to replace those problematic buttons.
Neye ihtiyacın var
Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
What if the flash button is not working? How will i open or fix it? Flash does not pop out
