Ana içeriğe geç
Nikon 1 J3 LCD Screen Replacement
Neye ihtiyacın var
    1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
      • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
      • Remove the screws under the flaps covering the HDMI and mini USB ports.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon 1 J3 LCD Screen Replacement: adım 2, 1 resimden 1.
      • Carefully pry back the back plate.
      • The plastic of the back plate may crack.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon 1 J3 LCD Screen Replacement: adım 3, 1 resimden 1.
      • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon 1 J3 LCD Screen Replacement: adım 4, 1 resimden 1.
      • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Austin Lackey
506 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G4, Passmore Fall 2017 USF Tampa, Team S11-G4, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G4
3 Üyeler
12 adet Kılavuz yazıldı
3Kılavuz Yorumları
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - Yanıt Paylaş
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - Yanıt Paylaş
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 57
Her zaman: 1,758
