Ana içeriğe geç
Nikon 1 J3 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon 1 J3 Motherboard Replacement, LCD Screen: adım 1, 2 resimden 1. Nikon 1 J3 Motherboard Replacement, LCD Screen: adım 1, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
  2. Nikon 1 J3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Nikon 1 J3 Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Nikon 1 J3 Motherboard Replacement: adım 4, 1 resimden 1.
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
  5. Nikon 1 J3 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Nikon 1 J3 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Nikon 1 J3 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Use the plastic opening tool to pry off the connectors shown
    • Using your finger, pry off the connection flap.
  6. Nikon 1 J3 Motherboard Replacement: adım 6, 3 resimden 1. Nikon 1 J3 Motherboard Replacement: adım 6, 3 resimden 2. Nikon 1 J3 Motherboard Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, pull out the shown connectors
  7. Nikon 1 J3 Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull back the black switches holding the connecting ribbons in place, and pull out the ribbons.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Lackey
479 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G4, Passmore Fall 2017 USF Tampa, Team S11-G4, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 998
