Ana içeriğe geç
Nikon 1 J5 Keypad Replacement
Neye ihtiyacın var
  1. Nikon 1 J5 Keypad Replacement, Remove Micro SD card and Battery: adım 1, 1 resimden 1.
    • Remove Micro SD card and Battery
  2. Nikon 1 J5 Keypad Replacement: adım 2, 3 resimden 1. Nikon 1 J5 Keypad Replacement: adım 2, 3 resimden 2. Nikon 1 J5 Keypad Replacement: adım 2, 3 resimden 3.
    • Remove 2 screws
    • Open plastic LCD connector cover
    • Lift FPC connector latch
    • Detach LCD FPC
  3. Nikon 1 J5 Keypad Replacement: adım 3, 3 resimden 1. Nikon 1 J5 Keypad Replacement: adım 3, 3 resimden 2. Nikon 1 J5 Keypad Replacement: adım 3, 3 resimden 3.
    • Remove 4 screws
    • Remove LCD module
  4. Nikon 1 J5 Keypad Replacement, Back Case: adım 4, 1 resimden 1.
    • WARNING!!! DO NOT TOUCH THESE Solder joints!!! High Voltage up to 300V..
    • Or discharge the flash condenser first, as per "Main PCB replace guide"
    • Remove 3 screws
  5. Nikon 1 J5 Keypad Replacement: adım 5, 3 resimden 1. Nikon 1 J5 Keypad Replacement: adım 5, 3 resimden 2. Nikon 1 J5 Keypad Replacement: adım 5, 3 resimden 3.
    • Left side, in connector bay, remove 2 screws.
    • Bottom, reomve 2 screws
    • Right side, remove 1 screw
  6. Nikon 1 J5 Keypad Replacement: adım 6, 1 resimden 1.
    • Peel here and remove 1 screw within.
  7. Nikon 1 J5 Keypad Replacement: adım 7, 2 resimden 1. Nikon 1 J5 Keypad Replacement: adım 7, 2 resimden 2.
    • Pop open back case and remove it from body.
  8. Nikon 1 J5 Keypad Replacement, Keypad: adım 8, 3 resimden 1. Nikon 1 J5 Keypad Replacement, Keypad: adım 8, 3 resimden 2. Nikon 1 J5 Keypad Replacement, Keypad: adım 8, 3 resimden 3.
    • Disconnect speaker
    • Disconnect keypad FPC
  9. Nikon 1 J5 Keypad Replacement: adım 9, 1 resimden 1.
    • Push latches from below
    • pop up and remove keypad.
Sonuç
Terrance
6.455 İtibar
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 214
