Ana içeriğe geç
Nikon COOLPIX P2 Case Replacement
Neye ihtiyacın var
  1. Nikon COOLPIX P2 Case Replacement, Case: adım 1, 1 resimden 1.
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Nikon COOLPIX P2 Case Replacement: adım 2, 1 resimden 1.
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Nikon COOLPIX P2 Case Replacement: adım 3, 1 resimden 1.
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nikon COOLPIX P2 Case Replacement: adım 4, 1 resimden 1.
    • Turn the camera so that the Wi-Fi adapter is facing you.
    FixBot'a Sor
    Yorum Ekle
  5. Nikon COOLPIX P2 Case Replacement: adım 5, 3 resimden 1. Nikon COOLPIX P2 Case Replacement: adım 5, 3 resimden 2. Nikon COOLPIX P2 Case Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
    FixBot'a Sor
    Yorum Ekle
  6. Nikon COOLPIX P2 Case Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool pry the back casing of the camera.
    FixBot'a Sor
    Yorum Ekle
  7. Nikon COOLPIX P2 Case Replacement: adım 7, 1 resimden 1.
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
    FixBot'a Sor
    Yorum Ekle
  8. Nikon COOLPIX P2 Case Replacement: adım 8, 2 resimden 1. Nikon COOLPIX P2 Case Replacement: adım 8, 2 resimden 2.
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessica Brough
135 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G28
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 1,634
