Ana içeriğe geç
Nikon COOLPIX P2 WiFi Card Replacement
Neye ihtiyacın var
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: adım 1, 1 resimden 1.
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: adım 2, 1 resimden 1.
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: adım 3, 1 resimden 1.
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: adım 4, 1 resimden 1.
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: adım 5, 3 resimden 1. Nikon COOLPIX P2 WiFi Card Replacement: adım 5, 3 resimden 2. Nikon COOLPIX P2 WiFi Card Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: adım 7, 1 resimden 1.
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: adım 8, 2 resimden 1. Nikon COOLPIX P2 WiFi Card Replacement: adım 8, 2 resimden 2.
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: adım 9, 2 resimden 1. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: adım 9, 2 resimden 2.
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: adım 10, 2 resimden 1. Nikon COOLPIX P2 WiFi Card Replacement: adım 10, 2 resimden 2.
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: adım 11, 1 resimden 1.
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: adım 12, 1 resimden 1.
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: adım 13, 1 resimden 1.
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: adım 14, 1 resimden 1.
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: adım 15, 1 resimden 1.
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: adım 16, 1 resimden 1.
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: adım 17, 1 resimden 1.
    • Gently pull the WiFi card out of the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joshua Avery
31 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G28
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 892
