Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide demonstrates how to remove the image sensor from your Nikon COOLPIX P500 camera.
Neye ihtiyacın var
Remove all the marked screws using a PH00 screwdriver.
Remove the two 3mm screws on the grip.
Remove the two 4mm screws on the side opposite the grip.
Remove the three 4mm screws on the base of the camera.
Remove the four 3mm screws on the base of the camera.
Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
Use a PH00 screwdriver to remove the two 2mm metal screws from the image sensor cover.
3 farklı kişi bu kılavuzu tamamladı.
