Ana içeriğe geç
Nikon COOLPIX P7700 Back Casing Replacement
Neye ihtiyacın var
  1. Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: adım 1, 2 resimden 1. Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: adım 1, 2 resimden 2.
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Back Casing Replacement: adım 2, 1 resimden 1.
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Back Casing Replacement: adım 3, 1 resimden 1.
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Back Casing Replacement: adım 4, 1 resimden 1.
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Back Casing Replacement: adım 5, 1 resimden 1.
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Back Casing Replacement: adım 6, 2 resimden 1. Nikon COOLPIX P7700 Back Casing Replacement: adım 6, 2 resimden 2.
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Back Casing Replacement: adım 7, 1 resimden 1.
    • Remove the back casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dustin Wahl
784 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,961
