Ana içeriğe geç
Nikon COOLPIX P7700 Focusing Screen Replacement
Neye ihtiyacın var
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: adım 1, 2 resimden 1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: adım 1, 2 resimden 2.
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 2, 1 resimden 1.
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 3, 1 resimden 1.
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 4, 1 resimden 1.
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 5, 1 resimden 1.
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 6, 2 resimden 1. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 6, 2 resimden 2.
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 7, 1 resimden 1.
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: adım 8, 1 resimden 1.
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 9, 1 resimden 1.
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 10, 3 resimden 1. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 10, 3 resimden 2. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 10, 3 resimden 3.
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 11, 2 resimden 1. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 11, 2 resimden 2.
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 12, 2 resimden 1. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 12, 2 resimden 2.
    • Lift and detach connector from board as shown.
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 13, 1 resimden 1.
    • Remove the board from the camera to locate lens opening
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 14, 1 resimden 1.
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 15, 1 resimden 1.
    • Lift the metal sheet up and out of the camera.
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 16, 1 resimden 1.
    • Locate the reflective lens.
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: adım 17, 1 resimden 1.
    • Remove the lens from the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dustin Wahl
784 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G7
3 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - Yanıt
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 2,031
