Ana içeriğe geç
Nikon COOLPIX P7700 Multi Selector Wheel Replacement
Neye ihtiyacın var
    1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Back Casing: adım 1, 2 resimden 1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Back Casing: adım 1, 2 resimden 2.
      • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
      • Remove the side panel.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 2, 1 resimden 1.
      • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 3, 1 resimden 1.
      • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 4, 1 resimden 1.
      • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 5, 1 resimden 1.
      • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 6, 2 resimden 1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 6, 2 resimden 2.
      • Begin separating the camera into two parts.
      • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
      FixBot'a Sor
      Yorum Ekle
    7. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 7, 1 resimden 1.
      • Remove the back casing.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement, Multi Selector Wheel: adım 8, 1 resimden 1.
      • Remove the four 4.3 mm screws located on the far right metal plate. Use the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 9, 2 resimden 1. Nikon COOLPIX P7700 Multi Selector Wheel Replacement: adım 9, 2 resimden 2.
      • Remove and replace wheel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Dustin Wahl
808 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G7
3 Üyeler
10 adet Kılavuz yazıldı
8Kılavuz Yorumları
Step 9: I believe that the multi-selector wheel component is soldered, 3 wires just visible in the photo for step 8. This will surely add to the time taken and difficulty.
I have a problem with this component. Firstly it's almost impossible to obtain the replacement parts, but if I could this guide would be invaluable; pictures are worth a thousand words! Thanks.
basstrom - Yanıt Paylaş
where can I get the item ( wheel ) ?
Best regards and thank you for the good explanation
fiteluetkehoff - Yanıt Paylaş
Where i can find this wheel for replacement?
skromnjagaserj - Yanıt Paylaş
See my comment above, for spray cleaning the wheel without any replacement. Unless your wheel is brokwn, you can try my suggestion. It works.
JY - Yanıt Paylaş
Please see my comment on the "general" method of fixing the wheel (using fast-drying contact cleaner) without ANY component replacement or unscrewing. It works really well but you may have to do it 1-3 times until all the dirt inside the wheel mechanism is removed. I have managed to restore my P7700 (after "fixing" the erratic Control Wheel and the dis-obedient Play button). Since then I have used the same method to fix the control wheel on my Samsung EX-1 camera (the control wheel was replaced twice by Samsung but the problem came back after a year or so). The root cause is probably a weak control wheel design (maybe tiny metal springs rotating over a base-plate with printed circuits). Now I know how to save money and trouble (for any compact camera with a similar control wheel design).
JY - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 51
Her zaman: 6,370
