Ana içeriğe geç
Nikon COOLPIX S3600 Battery Cover Replacement
Neye ihtiyacın var
  1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: adım 1, 2 resimden 1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Locate the battery cover on the right side of the bottom of the camera.
    • To open the cover, gently slide it in the direction indicated by the arrow.
  2. Nikon COOLPIX S3600 Battery Cover Replacement: adım 2, 3 resimden 1. Nikon COOLPIX S3600 Battery Cover Replacement: adım 2, 3 resimden 2. Nikon COOLPIX S3600 Battery Cover Replacement: adım 2, 3 resimden 3.
    • Once the battery cover door is open, insert the pointed end of a spudger underneath the metal door hinge.
    • Gently twist the spudger; the battery door cover should pop off.
    • Completely remove the cover from the hinge.
Sonuç
To reattach the battery cover door, align the metal hinge with the plastic cover and press the plastic cover downward until it snaps into place.
Kim Maxson
107 İtibar
1 Kılavuz yazıldı
Ekip
Colorado Springs, Team 1-3, May Spring 2015 Colorado Springs, Team 1-3, May Spring 2015 üyesi
UCCS-MAY-S15S1G3
6 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 575
